[fdo-trac] #739: Applying a schema containing an int64 identity property converts the property to autogenerated int32
FDO trac_fdo at osgeo.org
Fri Jan 14 10:18:57 EST 2011
   Reporter:  jng              |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:  3.6.0
  Component:  SQLite Provider  |     Version:  3.5.0
   Severity:  3                |    Keywords:
External_id:                   |
Comment(by traianstanev):
 There is no conversion happening -- the property is still int64 internally
 and you can use GetInt64 to get the value, but I assume the returned FDO
 schema is lying to you -- probably to make Map3D happy for some reason.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/739#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
