[fdo-trac] #739: Applying a schema containing an int64 identity property converts the property to autogenerated int32
FDO trac_fdo at osgeo.org
Fri Jan 14 11:06:29 EST 2011
   Reporter:  jng              |       Owner:  romicadascalescu
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:  3.6.0
  Component:  SQLite Provider  |     Version:  3.5.0
   Severity:  3                |    Keywords:
External_id:                   |
Comment(by romicadascalescu):
 I've attached a test file where I have a SQLite file having two classes:
  - first has PK Int64 auto-generated
  - second has PK Int64 not auto-generated
 Describe schema returns the right PK for classes.
 Could you provide some test code?
 Thanks,
 Romy.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/739#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
