[fdo-trac] #739: Applying a schema containing an int64 identity property converts the property to autogenerated int32
FDO trac_fdo at osgeo.org
Mon Jan 17 14:06:39 EST 2011
 Reporter:  jng              |         Owner:  romicadascalescu
     Type:  defect           |        Status:  closed
 Priority:  major            |     Milestone:  3.6.0
Component:  SQLite Provider  |       Version:  3.5.0
 Severity:  3                |    Resolution:  fixed
 Keywords:                   |   External_id:
Changes (by romicadascalescu):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I've fixed this issue, see below. You have two options to use or not FDO
 metadata.
 Author: romicadascalescu
 Date: 2011-01-17 11:00:39 -0800 (Mon, 17 Jan 2011)
 New Revision: 5863
    trunk/Providers/SQLite/Src/Provider/SltMetadata.cpp
 #504 SQLite provider. Improvements:
  - Remove a hack forcing a PK to FdoDataType_Int32. This code is not
 executed in case FDO metadata = true;
Ticket URL: <http://trac.osgeo.org/fdo/ticket/739#comment:9>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
