[fdo-trac] #740: Properties with NULL Values are not Included in XML Output
FDO trac_fdo at osgeo.org
Tue Jan 18 04:59:13 EST 2011
   Reporter:  crispinatime  |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  minor         |   Milestone:  3.6.0
  Component:  FDO API       |     Version:  3.6.0
   Severity:  3             |    Keywords:  xmlFeatureSerialize XML GML
External_id:                |
 When writing the content of a feature reader using the
 xmlFeatureSerialiser, any properties with NULL values are not included in
 the XML - this gives rise to gml:featureMembers being inconsistent within
 the same export as different records have different properties.
 Discussion here:
 If you use the xmlFeatureSerializer then the null properties will be
 absent in the output file, which would be a bug.
 http://osgeo-org.1803224.n2.nabble.com/Which-GML-version-is-supported-by-
 FDO-3-5-0-tt5906711.html#a5931980
Ticket URL: <http://trac.osgeo.org/fdo/ticket/740>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
