[fdo-trac] #742: Problem Compiling OpenSource_FDO on Debian Lenny
FDO trac_fdo at osgeo.org
Wed Jan 26 12:21:31 EST 2011
   Reporter:  dbx2011       |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.6.0
  Component:  Build System  |     Version:  3.6.0
   Severity:  2             |    Keywords:  Debian Lenny Compiling
External_id:                |
 I'm new here so a big Hello to you all.
 I've been trying to get OpenSource FDO to compile for a couple of days now
 without success its time to shout HELP! hopefully someone can help me
 solve this one.
 I think the issue might be something to do with gcc 4.2 in lenny, as when
 I try to compile versions 3.4 or 3.5 I run into this issue :
 [http://osgeo-org.1803224.n2.nabble.com/RE-mapguide-users-Compile-
 fdo-3-4-0-on-debian-lenny-td2164124.html]
 there is no rule to make xml-xalan apache module. I also get the same
 error when I try to compile any version of xml-xalan from source, although
 xalan installs fine from the .deb package or apt-get I think its version
 libxalan110-dev.
 Anyway I've tried setting the env vars
    FDO = [FDO OpenSource]/Fdo
    FDOUTILITIES = [FDO OpenSource]/Providers/Utilities
    FDOTHIRDPARTY = [FDO OpenSource]/ThirdParty
 And have tried with the internal version of gdal, and the one compiled on
 my system which is 1.7.3 , nothing seems to gt me past the error compiling
 xml-xalan. I've also tried the svn version - same error.
 I tried the cmake method as a last reort as detailed with versions 3.5 and
 3.6 but the thing fails with errors about python libs not found even
 thougn I have set them :
 -- Could not find module FindFDOInternal.cmake or a configuration file for
 package FDOInternal
 -- Could NOT find PythonLibs (missing: PYTHON_LIBRARIES
 PYTHON_INCLUDE_PATH)
 Each time I try to compile with gcc the appropriate /usr/local/fdo-3.*
 folder gets created, but the include folder never gets created so I am
 unable to proceed with MapGuide installation. I'm close to giving up could
 someone please help.
 I'm going to try to attach the output of my compile attempt with v3.6.0 as
 the problem is slightly different to that with the 3.3 and 3.5 version.
 Thanks
Ticket URL: <http://trac.osgeo.org/fdo/ticket/742>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
