[fdo-trac] #753: FDO XML: improper serializing of schemas with names starting with numbers
FDO trac_fdo at osgeo.org
Wed Mar 16 08:23:53 EDT 2011
 Reporter:  brentrobinson                   |         Owner:  brentrobinson
     Type:  defect                          |        Status:  closed
 Priority:  minor                           |     Milestone:
Component:  FDO API                         |       Version:  3.6.0
 Severity:  3                               |    Resolution:  fixed
 Keywords:  XML serialize namespace prefix  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 5915
 Author: brentrobinson
 Date: 8:23:12 AM, Wednesday, March 16, 2011
 Message:
 Ticket#753: Use leading '_', instead of '-' when the first character of a
 schema element is not valid in an XML name and needs to be encoded.
 Modified : /trunk/Fdo/UnitTest/SchemaTest.cpp
 Modified : /trunk/Fdo/UnitTest/XmlTest.cpp
 Modified : /trunk/Fdo/UnitTest/schema_merge1b.xml
 Modified : /trunk/Fdo/UnitTest/schema_merge2b_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_ref_err1_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_ref_err2_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_ref_err3_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_refs1a_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_refs1b_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_refs1c_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_refs2_master.txt
 Modified : /trunk/Fdo/UnitTest/schema_refs_err_master.txt
 Modified : /trunk/Fdo/Unmanaged/Src/Common/Xml/ReaderXrcs.cpp
 Modified : /trunk/Fdo/Unmanaged/Src/Common/Xml/WriterXrcs.cpp
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt
Ticket URL: <http://trac.osgeo.org/fdo/ticket/753#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
