[fdo-trac] #794: CurveString/CurvePolygon WKT roundtrip issues
FDO trac_fdo at osgeo.org
Wed Oct 19 09:51:23 EDT 2011
   Reporter:  MaksimS  |       Owner:  gregboone
       Type:  defect   |      Status:  new
   Priority:  major    |   Milestone:  3.6.0
  Component:  FDO API  |     Version:  3.6.0
   Severity:  3        |    Keywords:
External_id:           |
 When a !CurveString is created "manually" (hardcoded) using curve
 segments, resulting WKT returned by the {{{CurveString.Text()}}} is:
 {{{CURVESTRING XYZ (15 10 0 (LINESTRINGSEGMENT (20 10 0),
 CIRCULARARCSEGMENT (22.5 7.5 0, 20 5 0), LINESTRINGSEGMENT (15 5 0),
 LINESTRINGSEGMENT (15 10 0)))}}}
 Now, when I try to read above WKT back into IGeometry using
 {{{FgfGeometryFactory.CreateGeometry()}}} and above WKT string on input:
 {{{FgfGeometryFactory.CreateGeometry("CURVESTRING XYZ (15 10 0
 (LINESTRINGSEGMENT (20 10 0), CIRCULARARCSEGMENT (22.5 7.5 0, 20 5 0),
 LINESTRINGSEGMENT (15 5 0), LINESTRINGSEGMENT (15 10 0)))")}}}
 ...I keep getting following {{{IGeometry.Text()}}} result:
 CIRCULARARCSEGMENT (22.5 7.5 0, 20 5 0), LINESTRINGSEGMENT (15 5 0, 15 10
 0)))}}}
 ...and on the next rountrip, one coordinate is missing (!)
 BTW, !LineString/!Polygon roundtrip tests (similar to above example) pass
 just fine...
Ticket URL: <http://trac.osgeo.org/fdo/ticket/794>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
