[fdo-trac] #776: SHP provider: spatial index out of date is not recreated
FDO trac_fdo at osgeo.org
Fri Sep 2 15:20:45 EDT 2011
   Reporter:  danstoica  |       Owner:  gregboone
       Type:  defect     |      Status:  new
   Priority:  major      |   Milestone:  3.6.0
  Component:  FDO API    |     Version:  3.6.0
   Severity:  3          |    Keywords:
External_id:             |
 The issue occurs when a 3rd party application is editing the SHP file.
 Note the spatial index IDX file is FDO specific and it will not be
 updated. Thus it is getting stale.
 A solution is checking the timestamps of the SHP and IDX files. If the SHP
 file has been edited since the last IDX file change, that would indicate a
 3rd party edit to that SHP file. It is a valid solution to this problem
 since the IDX create/recreate/update is based on reading the current SHP
 records. Thus the timestamps will reflect the sequence of operations.
 The C++ function to get the filestamp is stat() which can retrieve the
 last modified date. It is available both on Windows and Linux.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/776>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
