[fdo-trac] #777: Improve WFS memory usage
FDO trac_fdo at osgeo.org
Tue Sep 6 09:45:00 EDT 2011
   Reporter:  gregboone     |       Owner:  gregboone
       Type:  defect        |      Status:  assigned
   Priority:  major         |   Milestone:  3.7.0
  Component:  WFS Provider  |     Version:  3.6.0
   Severity:  2             |    Keywords:
External_id:                |
Comment(by gregboone):
 Robin Newton wrote:
 > I guess I should have also asked: (c) Is FdoXmlFeatureReaderImpl
 > hanging on to all these features likely to be be a major factor in
 > memory use? To which my current answer would have to be "no".
 That was a bit hasty. It turned out my replication example was falling
 foul of the stack issue before it had a chance to exhaust heap space. With
 the stack issue dealt with a I get a memory exhaustion problem that can be
 fixed by tweaking the code to FdoXmlFeatureReaderImpl::ReadNext so that it
 releases features which aren't needed any more.
 I'm not quite sure what I'm going to do with this, but if I wanted to
 submit a patch for consideration for the next release of FDO, what's the
 etiquette?
 Is this something I should ask about on the 'internals' list?
 Thanks,
 Robin
Ticket URL: <http://trac.osgeo.org/fdo/ticket/777#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
