[fdo-trac] #790: Fix the issue that a normal transaction in RDBI may be held off by an "auto-select" transaction
FDO trac_fdo at osgeo.org
Fri Sep 23 06:00:03 EDT 2011
   Reporter:  samwang           |       Owner:  Romica Dascalescu
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.7.0
  Component:  GenericRdbms API  |     Version:  3.7.0
   Severity:  3                 |    Keywords:
External_id:                    |
 In the RDBI framework, transactions are ended strictly due to their
 nesting order. However, there are situations that between calling
 tran_begin and trans_end(for non query operations), a query is executed.
 This causes the non-query transaction not the top on transaction start,
 thus will fail to end. This ticket aims at fixing this problem by skipping
 transactions with ids which start with "auto-exec-" when trying to find a
 matching transaction to end.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/790>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
