[fdo-trac] #826: WFS from DigitalGlobel fails
FDO trac_fdo at osgeo.org
Tue Apr 10 21:59:15 EDT 2012
 Reporter:  stevenxu      |         Owner:  StevenXu
     Type:  defect        |        Status:  closed
 Priority:  major         |     Milestone:  3.7.0
Component:  WFS Provider  |       Version:  3.7.0
 Severity:  3             |    Resolution:  fixed
 Keywords:  WFS           |   External_id:  1452787
Changes (by stevenxu):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed it in trunk stream with submission r6437
 http://trac.osgeo.org/fdo/changeset/6437
 This problem occurred from FDO 3.6 and there are two problems result in
 the failure of DigitalGlobel.
 1. New element name was involved in Fdo.dll:
 Http request "
 https://services.digitalglobe.com/catalogservice/wfsaccess?CONNECTID=7ae07ed7%2Dda2d%2D4d65%2Dac04%2D8220b20c1b93&version=1.1.0&service=WFS&REQUEST=GetFeature&TYPENAME=DigitalGlobe%3AImageInMosaicFeature"
 It is used in FDO 3.6 and 3.7.
 It returns one new XML element named as "featureMembers".
 Http request "
 https://services.digitalglobe.com/catalogservice/wfsaccess?request=GetFeature&CONNECTID=7ae07ed7%2Dda2d%2D4d65%2Dac04%2D8220b20c1b93&version=1.0.0&service=WFS&REQUEST=GetFeature&TYPENAME=DigitalGlobe%3AImageInMosaicFeature"
 It is used in FDO 3.5.
 It returns the XML element "featureMember".
 Both of these Http requests will return one XML file which contains all
 feature information.
 The parser to this XML is hard-coded in the file
 \\fdo_depot\Fdo\Unmanaged\Src\Fdo\Xml\FeaturePropertyReaderImpl?.cpp and
 it only accepts the name "featureMember".
 This fix modified the code to handle both "featureMembers" and
 "featureMember" .
 2. One parser error in WFSProvider.dll:
 In FDO 3.6 and 3.7 the method "FdoWfsSchemaMerger::getXSDName" got the
 wrong result form URL
 http://services.digitalglobe.com:80/wfsservice/schemas/gml/3.1.1/base/gml.xsd?CONNECTID=7ae07ed7
 -da2d-4d65-ac04-8220b20c1b93"
 The right result is "gml.xsd" instead of "gml.xsd?CONNECTID=7ae07ed7-da2d-
 4d65-ac04-8220b20c1b93".
 This fix improved this parser to get the right XSD name.
 This problem hasn't occurred in FDO 3.5 for this code path hasn't been
 exercised in it.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/826#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
