[Fdo-trac] [fdo-trac] #840: Insert feature fails on table with computed column
FDO trac_fdo at osgeo.org
Tue Jul 10 01:43:30 PDT 2012
   Reporter:  gBecker            |       Owner:  danstoica
       Type:  defect             |      Status:  new
   Priority:  major              |   Milestone:  3.7.0
  Component:  SQLServer Spatial  |     Version:  3.6.0
   Severity:  3                  |    Keywords:
External_id:                     |
 When trying to insert a feature into a table with a computed column the
 insertion fails because this column/property must have been "NOT NULL".
 I also tried to set a dummy value for this column but this fails, too,
 because computed columns couldn't be set.
 So, my conclusion is that this must be a failure. I would have supposed
 that the property for the computed column must be marked as ReadOnly, but
 it wasn't. ReadOnly attribute was set to "false".
Ticket URL: <http://trac.osgeo.org/fdo/ticket/840>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
