[Fdo-trac] [fdo-trac] #834: Export layer data to SQLite becomes too slow
FDO trac_fdo at osgeo.org
Tue Jun 5 19:57:25 PDT 2012
   Reporter:  wyylling         |       Owner:  Ying Wang
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:  3.7.0
  Component:  SQLite Provider  |     Version:  3.7.0
   Severity:  3                |    Keywords:
External_id:  1449749.02       |
 1. Take the standard WW dump (TB_WW.dump also attached) and import it with
 TB2011
 2. Generate graphic with the standard display model (also attached)
 3. In Display manager select WW_Line with the right mouse taste and choose
 "Export Layer Data to SQLite..."
 4. After 2 seconds, the sqlite file is created.
 5. Take the same dump and import it with Map 2012 (inclusive structure
 updates)
 6. Generate graphic with the standard display model (also attached)
 7. In Display manager select WW_Line with the right mouse taste and choose
 Result:
 After 20 seconds the sqlite file is created.
 This is 10 times the time that was used with TB 2011
 Expected result:
 The SQLite file should be created after 2 seconds.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/834>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
