[Fdo-trac] [fdo-trac] #836: "Copying thirdparty dlls" postbuild step for PostgreSQL provider fails on first build from command line
FDO trac_fdo at osgeo.org
Fri Jun 15 07:09:59 PDT 2012
   Reporter:  jng                  |       Owner:  badreddinekaroui
       Type:  defect               |      Status:  new
   Priority:  trivial              |   Milestone:
  Component:  PostgreSQL Provider  |     Version:  3.7.0
   Severity:  3                    |    Keywords:
External_id:                       |
 There is a postbuild error "Copying thirdparty dlls" in the PostgreSQL
 provider project that always fails on the first clean build from the
 command-line.
 It doesn't happen again if you re-run the command line build thereafter.
 It's a bit annoying to not be able to have a fully clean first build.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/836>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
