[fdo-trac] #821: SL King Provider: Performance bottleneck when using partitioned indexes in Oracle
FDO trac_fdo at osgeo.org
Thu Mar 22 03:46:20 EDT 2012
Oracle
   Reporter:  sgamperl             |       Owner:  haris
       Type:  defect               |      Status:  new
   Priority:  major                |   Milestone:  3.6.0
  Component:  KingOracle Provider  |     Version:  3.6.0
   Severity:  3                    |    Keywords:
External_id:                       |
 There is a performance bottleneck when a partitioned index is created on
 an Oracle table. The Oracle tables have millions of rows and there exists
 about 1000 partitions per table. When we use these schema in a MapGuide
 map, the DescribeSchema command is very slow.
 I think the problem is the join to the USER_SDO_INDEX_INFO and the join to
 the USER_SDO_INDEX_METADATA table. Why is this join necessary for
 describing the schema?
 Maybe a option would be to specify the bounds of a feature class within
 the KingFdoViews or use the SDO_GEOM_METADATA information for the bounds.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/821>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
