[fdo-trac] #822: Linux 2013 cannot side by side with 2012
FDO trac_fdo at osgeo.org
Mon Mar 26 02:38:35 EDT 2012
   Reporter:  christinebao  |       Owner:  Christine Bao
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.6.0
  Component:  FDO API       |     Version:  3.7.0
   Severity:  3             |    Keywords:
External_id:  1453530       |
Comment(by christinebao):
 After fixing the duplicated port number, there is till the wrong FDO path
 problem:
 1. 2013 serverconfig.ini has fdoPath=/usr/local/fdo-3.7.0/lib, and
 trace.log also report that 3.7.0 fdo path is loaded. However for unknown
 reason, it seems the fdo.so in 3.6.0 is used. The wrong fdo version makes
 server crash when make fdo call.
 2. If rename 3.6.0 fdo folder to another name, 2013 works.
 3. This error does not happen in windows.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/822#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
