[fdo-trac] #831: 64-bit VC 2010 express compilation support
FDO trac_fdo at osgeo.org
Fri May 25 13:50:51 PDT 2012
   Reporter:  jng           |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.7.0
  Component:  Build System  |     Version:  3.7.0
   Severity:  3             |    Keywords:
External_id:                |
 Attached is a patch to allow compilation with 64-bit Visual C++ 2010
 express compiler. The patch does the following:
  * Modifies all build.bat files to allow the PlatformToolset to be
 overridden. We need to do this for VC express because the 64-bit compiler
 is only available in the Windows SDK v7.1, and only under the
 Windows7.1SDK platform toolset. Using the existing v100 toolset will not
 work.
  * Disables browse information on projects where it is enabled. This is
 because the there is no 64-bit version of bscmake.exe that comes with the
 64-bit compiler
 Also in this patch is a small fix for the UnitTestPostGIS project (it had
 bad 64-bit linker paths)
Ticket URL: <http://trac.osgeo.org/fdo/ticket/831>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
