[Fdo-trac] [fdo-trac] #844: SQL Server provider flipping X/Y coordinates for geometry (SRID between 4120 and 4999)
FDO trac_fdo at osgeo.org
Tue Sep 25 08:00:22 PDT 2012
4120 and 4999)
 Reporter:  jng                |         Owner:  romicadascalescu
     Type:  defect             |        Status:  closed
 Priority:  blocker            |     Milestone:  3.8.0
Component:  SQLServer Spatial  |       Version:  3.8.0
 Severity:  1                  |    Resolution:  fixed
 Keywords:                     |   External_id:
Changes (by romicadascalescu):
  * status:  new => closed
  * version:  3.7.0 => 3.8.0
  * resolution:  => fixed
  * milestone:  3.7.0 => 3.8.0
Comment:
 Fixed by code change:
 Revision: 6586
 Author: romicadascalescu
 Date: 10:53:51 AM, Tuesday, September 25, 2012
 Message:
 Ticket #844: SQL Server provider flipping X/Y coordinates for geometry
 Modified : /trunk/Providers/GenericRdbms/Inc/Geometry/Fgf/AllGeometry_c.h
 Modified : /trunk/Providers/GenericRdbms/Inc/Rdbi/methods.h
 Modified : /trunk/Providers/GenericRdbms/Inc/Rdbi/proto.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Connection/FdoRdbmsConnection.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsSimpleInsertCommand.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsSimpleSelectCommand.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsSimpleSelectCommand.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsSimpleUpdateCommand.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLBuilder.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPropBindHelper.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/Gdbi/GdbiCommands.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/Gdbi/GdbiCommands.h
 Modified : /trunk/Providers/GenericRdbms/Src/Gdbi/GdbiStatement.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/Gdbi/GdbiStatement.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/Geometry/Fgf/AllGeometry_c.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/MySQL/Driver/geom_srid.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/MySQL/Driver/geom_srid.h
 Modified : /trunk/Providers/GenericRdbms/Src/MySQL/Driver/rdbi_init.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/geom.c
 Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h
 Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c
 Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/geom_srid.c
 Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/geom_srid.h
 Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/rdbi_init.c
 Modified : /trunk/Providers/GenericRdbms/Src/Rdbi/geom_srid.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerConnection.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerConnection.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerFilterProcessor.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerProcessors.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerProcessors.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/crt_cursor.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/fre_cursor.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/geom.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/proto_p.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/rdbi_init.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/structs.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/SQLServerSpatial/SqlServerFdoSqlCmdTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/SQLServerSpatial/SqlServerFdoSqlCmdTest.h
Ticket URL: <http://trac.osgeo.org/fdo/ticket/844#comment:5>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
