[Fdo-trac] [fdo-trac] #871: Cannot build 32-bit/64-bit openssl from the same directory
FDO trac_fdo at osgeo.org
Thu Aug 1 05:50:31 PDT 2013
 Reporter:  jng           |         Owner:  gregboone
     Type:  defect        |        Status:  closed
 Priority:  major         |     Milestone:
Component:  Build System  |       Version:
 Severity:  3             |    Resolution:  wontfix
 Keywords:                |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 *sigh* GDAL has the same problem. Fixing this won't do anything because we
 can't build x86/x64 GDAL off of the same src directory. Fixing GDAL to put
 libs and object files in separate dirs is too much effort.
 I'll just suck it up and use platform-specific build dirs just like
 before.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/871#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
