[Fdo-trac] [fdo-trac] #878: Regression: Common Expression Engine cannot understand scientific notation when the coefficient is a decimal
FDO trac_fdo at osgeo.org
Sun Dec 22 20:02:31 PST 2013
   Reporter:  christinebao  |       Owner:  david.ji@…
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.8.0
  Component:  FDO API       |     Version:  3.8.0
   Severity:  3             |    Keywords:
External_id:  DE6337        |
 Reported by Autodesk QA:
 '''Steps:'''
 1. Install Deutsch Map3D L014AK
 2. Create an SHP FDO connection to connect the attached file region.shp
 3. Add to Map with Query
 Area( Geometry ) > 1.5e+11
 '''Result:'''
 All the 34 features(check it in data table) are added to map, the filter
 doesn't work.
 It works fine if the query are:
 Area( Geometry ) > 2e+11
 Area( Geometry ) > 150000000000
Ticket URL: <http://trac.osgeo.org/fdo/ticket/878>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
