[Fdo-trac] [fdo-trac] #862: Do not query table-valued inline functions in SpatialContextReader
FDO trac_fdo at osgeo.org
Wed Feb 27 02:35:37 PST 2013
   Reporter:  gBecker            |       Owner:  danstoica
       Type:  defect             |      Status:  new
   Priority:  major              |   Milestone:  3.8.0
  Component:  SQLServer Spatial  |     Version:  3.7.0
   Severity:  3                  |    Keywords:
External_id:                     |
 If you have table-valued functions in your SQL Server Database that
 returns a table with spatial columns then you get an error when trying to
 determine the extent of the data. The following error is listed in
 MapGuide error.log:
  Error: An exception occurred in FDO component.
         Error occurred in Feature Source
 (Session:05eea926-80b9-11e2-8000-002264a7285f_en_MTI3LjAuMC4x0AFC0AFB0AFA
 //3c1658ff-82a7-44a9-9005-3f262b0cb02d.FeatureSource): RDBMS:
 [Microsoft][SQL Server Native Client 10.0][SQL Server]Parameters were not
 supplied for the function
 'FFM_Fes.cdc.fn_cdc_get_all_changes_dbo_fes_AlteGeometrien'.
 Since table-valued functions are supposable not supported in SQL Server
 Provider for FDO, the solution could be to just query SQL Server objects
 that are not of type 'function'. I think the SQL to query the extent of
 the spatial data is in this
 file:[http://trac.osgeo.org/fdo/browser/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/Rd/SpatialContextReader.cpp]
 Changing the WHERE-clause to
  where ((f.name in ( 'geometry','geography' ) or e.object_id is not null)
 AND a.type <> 'if')
 should solve the problem, I think.
 Maybe there are other places to change!
Ticket URL: <http://trac.osgeo.org/fdo/ticket/862>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
