[Fdo-trac] [fdo-trac] #761: Full 64-bit Linux support
FDO trac_fdo at osgeo.org
Thu Jul 11 17:37:30 PDT 2013
   Reporter:  rafael       |       Owner:  gregboone
       Type:  enhancement  |      Status:  new
   Priority:  major        |   Milestone:  3.8.0
  Component:  FDO API      |     Version:  3.5.0
   Severity:  2            |    Keywords:
External_id:               |
Changes (by gregboone):
  * severity:  3 => 2
  * milestone:  3.6.0 => 3.8.0
Comment:
 I am testing With:
 OS: CentOS release 6.4 (Final)
 LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
 Compiler: GCC 4.7
 Notes:
 1) In order to install the required upgraded GCC 4.7 compiler follow :
 http://superuser.com/questions/381160/install-gcc-4-7-on-centos
 2) In order to switch to the new compiler run : scl enable devtoolset-1.1
 bash
 3) to switch back to the original gcc version: exit
 4) I also Installed glibc.i686 - "sudo yum install glibc.i686"
Ticket URL: <http://trac.osgeo.org/fdo/ticket/761#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
