[Fdo-trac] [fdo-trac] #865: King Oracle - Number(5, 0) with negative values return 0
FDO trac_fdo at osgeo.org
Tue Jun 11 23:47:03 PDT 2013
#865: King Oracle - Number(5,0) with negative values return 0
   Reporter:  croux    |       Owner:  gregboone
       Type:  defect   |      Status:  new
   Priority:  major    |   Milestone:  3.8.0
  Component:  FDO API  |     Version:  3.7.0
   Severity:  3        |    Keywords:
External_id:           |
 I have a Field Number(5,0), each value is between 0 and -10, When I use
 http://localhost/mapguide/schemareport/describeschema.php (View data) or
 make a thematic with this field, all values become 0.
 With Autodesk providers I have the real value (0 to -10)
 I have another table with a field number(10,0). (values between 0 to
 26000) all think OK
 the describeschema.php return all rows with good values.
 But if I execute the sql query
 'update table set myfield=-myfield' --> (values between 0 to -26000)
 the describeschema.php  return no row : Total Entries: -1
Ticket URL: <http://trac.osgeo.org/fdo/ticket/865>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
