[Fdo-trac] [fdo-trac] #864: BUG in SQL Server Spatial FDO provider when using filter
FDO trac_fdo at osgeo.org
Fri Oct 4 14:53:19 PDT 2013
 Reporter:  sreckol                |         Owner:  danstoica
     Type:  defect                 |        Status:  reopened
 Priority:  critical               |     Milestone:  3.8.0
Component:  SQLServer Spatial      |       Version:  3.8.0
 Severity:  3                      |    Resolution:
 Keywords:  MSSQL, PostGis Filter  |   External_id:
Changes (by sreckol):
 * cc: sreckol (added)
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 There is still problem when selecting entities on map.
 When zooming and panning SQL qurey is OK, but when select on map is used,
 then SQL query is still the same (without brackets in filter) and because
 of that everything hangs out on large table ...
Ticket URL: <http://trac.osgeo.org/fdo/ticket/864#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
