[Fdo-trac] [fdo-trac] #885: OGR Provider: allow for estimated OGR extent in GetExtent
FDO trac_fdo at osgeo.org
Thu Apr 3 00:23:04 PDT 2014
   Reporter:  gabrimonfa  |       Owner:  gregboone
       Type:  defect      |      Status:  new
   Priority:  major       |   Milestone:  3.8.0
  Component:  FDO API     |     Version:  3.8.0
   Severity:  3           |    Keywords:
External_id:              |
 In file OgrProvider.cpp, function GetExtent() the call to the ogr function
 GetExtent is done passing bForce=TRUE.
 In a recent ogr commit (that will appear in gdal 1.11) when bForce is
 FALSE, a fast path is used to return an estimated extent instead of the
 expensive true one.
 IMHO this should be the default path thus I proposed to flip the bForce
 parameter from TRUE to FALSE to allow the use of the estimated extent
Ticket URL: <http://trac.osgeo.org/fdo/ticket/885>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
