[Fdo-trac] [fdo-trac] #887: Update KingOracle for FDO 3.9.0
FDO trac_fdo at osgeo.org
Wed Apr 9 14:55:27 PDT 2014
   Reporter:  gregboone            |       Owner:  haris
       Type:  task                 |      Status:  new
   Priority:  major                |   Milestone:  3.9.0
  Component:  KingOracle Provider  |     Version:  3.9.0
   Severity:  2                    |    Keywords:
External_id:                       |
Description changed by gregboone:
Old description:
New description:
 - Improved speed of describe schema; for oracle schema with 200+ classes
 and multiple geometries per class it was more then 60 sec, now around 8-9
 sec;
 - Multiple geometries in one class and geometries can have different srid
 - Fix: inserting/updating  NULL geometries
 - Fix: INT64 read as signed from Oracle
 - Fix: insert/update blob columns
 - Fix: Table which is versioned under Oracle Workspace Manager is now used
 with table original name ( not _LT )
 - Oracle client 11.2
 - Fix: if geometry column in one table have points written using oracle
 two different ways to write point ( elem_info ordinates or sdo_point
 attribute ); it could end up reading wrong values
Ticket URL: <http://trac.osgeo.org/fdo/ticket/887#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
