[Fdo-trac] [fdo-trac] #879: ArcSDE provider does not work AIM Server with 10.1 client dlls
FDO trac_fdo at osgeo.org
Thu Jan 16 02:43:36 PST 2014
   Reporter:  kwi              |       Owner:  Dan Stoica
       Type:  defect           |      Status:  new
   Priority:  critical         |   Milestone:  3.8.0
  Component:  ArcSDE Provider  |     Version:  3.8.0
   Severity:  2                |    Keywords:
External_id:  DE4176           |
Changes (by kwi):
  * external_id:  => DE4176
Comment:
 Solution:[[BR]]
 - Increased the size of the Description string[[BR]]
 - Changed the approach from dynamic allocation to static allocation for a
 number of members. The debugger shows ArcSDELongTransactionReader::reset
 () is corrupting memory. Therefore avoided its usage by removing its
 functionality. Note without full Map3D stack is hard to tell how exactly
 this is fixing the problem.[[BR]]
 In any case it seems to work now.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/879#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
