[Fdo-trac] [fdo-trac] #883: Unit Test Suite instability
FDO trac_fdo at osgeo.org
Fri Mar 14 04:58:44 PDT 2014
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  major    |   Milestone:
  Component:  FDO API  |     Version:
   Severity:  3        |    Keywords:
External_id:           |
 I recently ran most of the FDO unit test suite and the results were
 somewhat unsettling:
 The results so far can be found in this spreadsheet (with CppUnit failures
 included):
 https://docs.google.com/spreadsheet/ccc?key=0AhBgYUE6W7xydEhmQjBIUHpUSzNGMFpLYWE4YmRSWnc&usp=drive_web#gid=0
 Some of the identified causes for these failures thus far are due to:
  * SHP: Unit tests referencing test data that was removed in #230
  * GenericRdbms: Tests referencing the Autodesk.Oracle FDO provider
  * GenericRdbms: Small changes to the expected output and the master txt
 files have not been updated
  * GenericRdbms: An improperly initialized wchar_t array in
 UnitTestUtil::Sql2Db() causing buffer overrun errors in SQL Server, MySQL
 and PostGis test runners in x64 release mode.
  * GenericRdbms: ExtendedCoordSys.txt not copied to the $OUTDIR/com
 directory
  * GenericRdbms: postgis_fdo_sys.sql and postgis_fdo_sys_idx.sql not
 copied to the $OUTDIR/com directory
  * SDF: Segfaulting test runner on Ubuntu due to missing realpath() fixes
 not ported over from the linux64 sandbox.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/883>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
