[Fdo-trac] [fdo-trac] #864: BUG in SQL Server Spatial FDO provider when using filter
FDO trac_fdo at osgeo.org
Sun May 11 01:59:20 PDT 2014
 Reporter:  sreckol                |         Owner:  danstoica
     Type:  defect                 |        Status:  reopened
 Priority:  critical               |     Milestone:  3.8.0
Component:  SQLServer Spatial      |       Version:  3.8.0
 Severity:  3                      |    Resolution:
 Keywords:  MSSQL, PostGis Filter  |   External_id:
Comment(by jng):
 Ok, the original fix applied to the FdoIFilterProcessor implementation at
 the GenericRdbms level.
 However, the SQL Server provider uses its own FdoIFilterProcessor
 implementation which does not have this logic.
 The attached patch (864_sqlserver.patch) applies this bracketing logic.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/864#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
