[Fdo-trac] [fdo-trac] #906: SdfIndexedScrollableFeatureReader::ReadNext() return true again after read finish
FDO trac_fdo at osgeo.org
Tue Apr 28 19:15:20 PDT 2015
finish
   Reporter:  christinebao  |      Owner:  christine bao
       Type:  defect        |     Status:  new
   Priority:  major         |  Milestone:  4.1.0
  Component:  FDO API       |    Version:  4.0.0
   Severity:  3             |   Keywords:
External ID:  DE22116       |
 Reported by Autodesk QA:
 Steps to reproduce:
 1. load the attached mgp to your map server site
 2. put the attached rest.conf file to folder ..Autodesk Infrastructure Web
 Server Extension 2016\www\GeoREST\conf  (need to update the server IP to
 yours and the port number to server matching port)
 3. in browser, input URL http://[your server
 ip]:99/rest/data/hotel/.xml?orderfields=FeatId
 result: the hotel feature class has only 3 features. but the result of
 step3 has many times more than 3 records.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/906>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
