[Fdo-trac] [fdo-trac] #910: Extend FdoWmsOvClassDefinition with a property for CRS name to be used as spatial context name
FDO trac_fdo at osgeo.org
Wed Jul 8 01:49:00 PDT 2015
   Reporter:  kwi           |      Owner:  kwi
       Type:  enhancement   |     Status:  new
   Priority:  major         |  Milestone:  4.1.0
  Component:  WMS Provider  |    Version:  4.0.0
   Severity:  2             |   Keywords:
External ID:                |
 On the WMS provider, every child class inherits the properties from the
 base class, when one exist.
 As the geometry property contains the spatial context, every class
 inherits the spatial context association from the base class.
 This leads to the fact that even when the child class has the default WMS
 CRS (EPSG:4326) assigned, but not the base class, the child will get the
 spatial context with the CRS from the base class. This is then a different
 one than the default CRS.
 It can be verified with this link:
 https://mapsengine.google.com/12700653833057327143-17379123781214007005-4/wms/?version=1.3.0
 The WMS service itself has the EPSG:4326 as the spatial context.
 So all feature classes in FDO have a different spatial context as the WMS
 service itself, which can lead to problems.
 The proposed fix is to give the FdoWmsOvClassDefinition a spatial CRS
 property, to be independent from the geometry property of the class
 itself. This CRS of the FdoWmsOvClassDefinition can be different than the
 one from the geometry property.
 Two methods to Set & Get the CRS will also be added.
 So that 3rd party applications can use the CRS property of the class
 definition additionally to the CRS of the geometry property.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/910>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
