[Fdo-trac] [fdo-trac] #934: Fix GenericRdbms unit test baseline
FDO trac_fdo at osgeo.org
Sat Dec 2 08:29:30 PST 2017
 Reporter:  jng               |        Owner:  jng
     Type:  task              |       Status:  assigned
 Priority:  major             |    Milestone:
Component:  GenericRdbms API  |      Version:
 Severity:  3                 |   Resolution:
 Keywords:                    |  External ID:
Description changed by jng:
Old description:
> There's a whole series of backlogged patches against various
> GenericRdbms-based FDO providers (primarily for `OSGeo.PostgreSQL` and
> `OSGeo.SQLServerSpatial`) that I'd like to see applied, but before I do
> that, I want to make sure the GenericRdbms test suite baseline is all
> tests passing.
> Currently, this is not the case. With this environment:
>  * SQL Server 2017 (on Linux)
>  * MySQL 5.5
>  * PostgreSQL 9.5/PostGIS 2.4
> We have the following failures:
> SQL Server:
> !!!FAILURES!!!
> Test Results:
> Run:  274   Failures: 4   Errors: 0
> 1) test: SqlServerFdoApplySchemaTest.TestSchema (F) line: 1663
> Common\UnitTestUtil.cpp
>  "Output file SQLServerSpatial_8759_apply_schema_test6_LPhF.xml differs
> from expected output file
> SQLServerSpatial_8759_apply_schema_test6_master.txt"
> 2) test: SqlServerFdoApplySchemaTest.TestOverrideErrors (F) line: 1663
>  "Output file
> SQLServerSpatial_8759_SQLServerSpatial_8759_apply_schema_overrides_err1SP.txt
> differs from expected output file
> apply_schema_overrides_err1SP_master.txt"
> 3) test: SqlServerFdoApplySchemaTest.TestNoMeta (F) line: 1663
>  "Output file
> SQLServerSpatial_8759_SQLServerSpatial_8759_apply_no_meta_err2.txt
> differs from expected output file apply_no_meta_err2_master.txt"
> 4) test: SqlServerSchemaMgrTests.testConfigError (F) line: 2051
> Common\SchemaMgrTests.cpp
>  "pMessage && expectedMessage.ICompare(pMessage) == 0"
> PostgreSQL:
> !!!FAILURES!!!
> Test Results:
> Run:  131   Failures: 4   Errors: 0
> 1) test: PostGisFdoSpatialContextTest.testAxes (F) line: 190
> PostGis\PostGisFdoSpatialContextTest.cpp
>  "wrong part of WKT removed, see log"
> 2) test: PostGisSchemaMgrTests.testGenDefault (F) line: 1663
>  "Output file PostGIS_8391_gen_default1.xml differs from expected output
> file PostGIS_8391_gen_default1_PostGIS_master.txt"
> 3) test: PostGisFdoApplySchemaTest.TestSchema (F) line: 1663
>  "Output file PostGIS_8391_apply_schema_test6_LPhF.xml differs from
> expected output file PostGIS_8391_apply_schema_test6_master.txt"
> 4) test: PostGisFdoApplySchemaTest.TestNoMeta (F) line: 1663
>  "Output file PostGIS_8391_apply_no_meta_test1.xml differs from expected
> output file PostGIS_8391_apply_no_meta_test1_master.xml"
> MySQL:
> !!!FAILURES!!!
> Test Results:
> Run:  244   Failures: 2   Errors: 1
> 1) test: MySqlFdoApplySchemaTest.TestSchema (F) line: 1223
>  "RDBMS: Duplicate entry 'aCxdATA-Acad' for key 'f_classdef_schnm_idx'
> 2) test: MySqlFdoApplySchemaTest.TestOverrideErrors (F) line: 1663
>  "Output file MySql_10680_MySql_10680_apply_schema_overrides_err1.txt
> differs from expected output file apply_schema_overrides_err1_master.txt"
> 3) test: MySqlReaderTest.TestExceptionalCase (E)
>  "caught unknown exception"
> Most of these failures can be fixed by:
>  1. General: Removing whitespace around certain master text files that
> are not present in the generated result
>  2. General: Adding source file/line number to the `<error>` element of
> to `apply_schema_test6_master.txt`
>  3. MySQL: Un-expected exception due to running a SQL query using a table
> name in incorrect case.
New description:
 There's a whole series of backlogged patches against various GenericRdbms-
 tests passing.
  * MySQL 5.5
 SQL Server:
 !!!FAILURES!!!
 Test Results:
  "Output file
  "Output file
 SQLServerSpatial_8759_SQLServerSpatial_8759_apply_no_meta_err2.txt differs
 PostgreSQL:
 !!!FAILURES!!!
 Test Results:
 MySQL:
 !!!FAILURES!!!
 Test Results:
  1. General: Removing whitespace around certain master text files that are
  2. General: Adding source file/line number to the `<error>` element of to
  4. SqlServerSchemaMgrTests.testConfigError: Load an alternative
 configuration document for the test case that does not use OracleProvider
 schema mappings.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/934#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
