[Fdo-trac] [fdo-trac] #935: Failure stripping PostGIS axis from srid=2000
FDO trac_fdo at osgeo.org
Sat Dec 9 23:33:11 PST 2017
 Reporter:  jng            |        Owner:  gregboone
     Type:  defect         |       Status:  new
 Priority:  major          |    Milestone:
Component:  Utilities API  |      Version:
 Severity:  3              |   Resolution:
 Keywords:                 |  External ID:
Description changed by jng:
Old description:
> PostGIS spatial context test is failing for srid=2000 with this WKT:
> PROJCS["Anguilla 1957 / British West Indies Grid",GEOGCS["Anguilla
> 1957",DATUM["Anguilla_1957",SPHEROID["Clarke 1880
> (RGS)",6378249.145,293.465,AUTHORITY["EPSG","7012"]],AUTHORITY["EPSG","6600"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4600"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-62],PARAMETER["scale_factor",0.9995],PARAMETER["false_easting",400000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","2000"]]
> The fixed WKT is malformed at the end (note the lack of comma before the
> last `AUTHORITY` element
> (RGS)",6378249.145,293.465,AUTHORITY["EPSG","7012"]],AUTHORITY["EPSG","6600"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4600"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-62],PARAMETER["scale_factor",0.9995],PARAMETER["false_easting",400000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]AUTHORITY["EPSG","2000"]]
New description:
 After #934, the PostGIS suite has this one last test failure
Ticket URL: <https://trac.osgeo.org/fdo/ticket/935#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
