[Fdo-trac] [fdo-trac] #956: Cannot build in GCC 7.x
FDO trac_fdo at osgeo.org
Fri May 18 04:43:03 PDT 2018
   Reporter:  jng           |      Owner:  jng
       Type:  defect        |     Status:  assigned
   Priority:  major         |  Milestone:
  Component:  Build System  |    Version:
   Severity:  3             |   Keywords:
External ID:                |
 I tried to build FDO trunk on Ubuntu 18.04 LTS, which includes GCC 7.x but
 it fails due to the following:
  * General: Errors of the form {{{invalid conversion from ‘wchar_t’ to
 ‘wchar_t*’}}} in {{{'\0'}}} assignment due to {{{-fpermissive}}}. Fix: Fix
 up the incorrect assignments.
  * MySQL Driver: The {{{<string>}}} header included in {{{stdafx.h}}} now
 complains about {{{errno}}} due to finding {{{errno.h}}} in the MySQL
 Driver directory before {{{<cerrno>}}}. Fix: Rather that fight with
 include path precedence, just rename {{{errno.h}}} to {{{drv_errno.h}}} so
 {{{<string>}}} will properly resolve errno in {{{<cerrno>}}}
Ticket URL: <https://trac.osgeo.org/fdo/ticket/956>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
