[fdo-users] GDAL FDO provider with raster performance enhancements
Thu Aug 23 09:38:46 EDT 2007
robert fritz wrote:
> Hi,
> I installed the new GDAL FDO provider with raster performance
> enhancements (http://trac.osgeo.org/fdo/wiki/FdoGdalNotes) on MGE 2008.
> When I execute the configbuilder.php an "An exception occurred in FDO
> component. FDO Provider Not Registered Exception occurred in method
> MgFdoConnectionManager.Open at line 259 in file
> c:\build_bond_area\Bond_Nightly\BUILD_41.3\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
> " occurs. It seems that the function $tmpSpatialContextReader =
> $featureService->GetSpatialContexts($tmpResource, false); causes the
> message.
> I have no idea what is going wrong. I tried different raster datasets
> (tifs, png) but got the  same error.
I'm not clear on why you would be getting as far as a GetSpatialContexts()
call before hitting a "provider not registered exception" but I don't
know how the configbuilder.php is setup.  Does the provider work with
MGE for displaying raster data?
The first thing I would check is that the provider is properly listed
in the providers.xml file.  I believe FDO is very sensitive to getting
version numbers right in this file for instance.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the fdo-users mailing list
