[fdo-users] Failed to process the given spatial condition
Dan Stoica dan.stoica at autodesk.com
Mon Dec 10 10:11:04 EST 2007
This is the default error message when ArcSDE returns an error in spatial condition cases. I'm surprised there is no native error message.
Can you debug and see exactly where it fails? What is in the spatial filter?
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of simon hope
Sent: Sunday, December 09, 2007 3:20 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Failed to process the given spatial condition
Hello,
I've come across an issue which i think i may have come across before [1]. I
am using the ArcSDE provider:
  <FeatureProvider>
    <Name>OSGeo.ArcSDE.3.2</Name>
    <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>
    <Description>Read/write access to an ESRI ArcSDE-based data store, using
Oracle and SQL Server.</Description>
    <IsManaged>False</IsManaged>
    <Version>3.2.1.0</Version>
    <FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
    <LibraryPath>ArcSDEProvider.dll</LibraryPath>
  </FeatureProvider>
I am setting a spatial filter on the select query then attempting to set a
feature reader by executing the query:
OSGeo.FDO.Commands.Feature.IFeatureReader featReader = qrySelect.Execute();
At which point i get an exception: 'Failed to process the given spatial
condition'. Has anybody successfully managed to create a spatial filter
using the ArcSDE 9.2 v3.2 provider?
Cheers
Simon
[1].http://www.nabble.com/Failed-to-process-the-given-spatial-condition-to13205208s16610.html#a13223966
View this message in context: http://www.nabble.com/Failed-to-process-the-given-spatial-condition-tp14242828s18162p14242828.html
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
