[fdo-users] SHP modifications issue
Dan Stoica dan.stoica at autodesk.com
Tue Jan 16 11:22:57 EST 2007
The files are flushed when the connection is closed.
The DBF file is compressed (i.e. get rid of the deleted rows) when all the connections are closed.
Also, SHP connection has a method Flush() which can be used programatically.
Which one is the case here?
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Ytse
Sent: Tuesday, January 16, 2007 3:56 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] SHP modifications issue
I'm using FDO 3.0 to modify (insert/update/delete) an
SHP.
Everything's fine, I can read/write the SHP as I want
to.
My issue occurs when I try to read the SHP using
either ArcView or Mapguide viewer, they are able to
display deleted objects or won't diplay newly added
objects.
If I edirt the DBF file I can actually see that my
deleted objects are still within, tagged by a "*"
Am I missing a step, like a "save" (commit?) command ?
Note that I'm not using fdo transactions (not an SHP
capability)
I'm really stuck and don't understand what's
happening, I'm really requiring your help here as
that's quite urgent, I have to present a beta version
of my current work this week and that's the only
remaining trouble :((
Bye & thx in advance
___________________________________________________________________________
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions !
Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses
http://fr.answers.yahoo.com
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
