[fdo-users] SHP modifications issue
Ytse bill_gfr at yahoo.fr
Tue Jan 16 13:34:26 EST 2007
Thanks everyone (I'm including Dan & Pierre)
I've downloaded and built FDO 3.2 for Windows but I'm
not quite sure which DLL I have to use.
I've added references to the managed OSGEO.* DLL's in
my C# solution but when I try to build the website I
have a "unable to find specified module 0x8007007E"
error
That's one I had earlier and I found the cause at this
time, the unmanaged DLL's refered by the managed DLL's
have to be some place where windows can find them
(current directory, system directory, whatever
directory from the 'path' environment variable)
That was ok for my 3.0 use as soon as I had the
following directory added to my path :
C:\Program
Files\Autodesk\MapGuideEnterprise2007\Server\Bin\FDO
but now it won't work, so I guess I'm missing a couple
dlls in my FDO directory.
I've copied all the files from
- Fdo\Managed\bin\release
- Fdo\Unmanaged\bin\win32\release
- Providers\SHP\Managed\bin\release
- Providers\SHP\bin\win32\release
and that won't work
I've tried adding all the dlls that could be found in
"ThirdParty" subdirectories, that still won't build.
If anyone can redirect me to a list of all the
required dlls for an external windows application, I'd
really be glad.
Thanx again
--- Robert Fortin <robert.fortin at autodesk.com> a
écrit :
> There was an issue in 3.0 with deleted feature.  The
> feature were only tagged as deleted and never
> removed from the shp/dbf file. This mean they were
> initially visible in ArcView until you did a refresh
> in which case they would be made invisible (but
> still present in the files).
> We fixed this in 3.1. The deleted feature will only
> be tagged as deleted until the connection is
> released at which point they will get removed from
> the dbf and shp file.
> RF
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf
> Of Ytse
> Sent: Tuesday, January 16, 2007 3:56 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] SHP modifications issue
> I'm using FDO 3.0 to modify (insert/update/delete)
> an SHP.
> Everything's fine, I can read/write the SHP as I
> want to.
> My issue occurs when I try to read the SHP using
> either ArcView or Mapguide viewer, they are able to
> display deleted objects or won't diplay newly added
> objects.
> If I edirt the DBF file I can actually see that my
> deleted objects are still within, tagged by a "*"
> Am I missing a step, like a "save" (commit?) command
> Note that I'm not using fdo transactions (not an SHP
> capability)
> I'm really stuck and don't understand what's
> happening, I'm really requiring your help here as
> that's quite urgent, I have to present a beta
> version of my current work this week and that's the
> only remaining trouble :((
> Bye & thx in advance
___________________________________________________________________________
> Découvrez une nouvelle façon d'obtenir des réponses
> à toutes vos questions !
> Profitez des connaissances, des opinions et des
> expériences des internautes sur Yahoo!
> Questions/Réponses http://fr.answers.yahoo.com
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions !
Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses
More information about the fdo-users mailing list
