[fdo-users] Compile problems, any ideas?
Traian Stanev traian.stanev at autodesk.com
Wed Jul 11 13:04:18 EDT 2007
Not sure. I personally haven't seen this exact problem before. Why do
you think runConfigure is failing? File permission issue?
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Gregor Mosheh
Sent: Wednesday, July 11, 2007 1:00 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] Compile problems, any ideas?
Traian Stanev wrote:
> You can go into the ThirdParty/apache directory and run the Xerces
build
> by itself to see if it succeeds or not. There should be a small shell
> script that does the under ThirdParty/apache.
Your fix (with a twist) does work. And thanks a million!
( cd Thirdparty/apache/xml-xerces/c/src/xercesc ; ./configure )
./build_thirdparty.sh
Tracking down this bug a bit, it seems that Xerces's runConfigure is
buggy. "./runConfigure -p linux" just returns a usage message, and I
know for a fact that that's the proper calling syntax since I use xerces
on other machines for other projects.
Should I file this as a build-bug, or is it already fixed in the 3.2.2
beta?
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting
services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
