[fdo-users] Compile problems, any ideas?
Gregor Mosheh gregor at hostgis.com
Wed Jul 11 13:32:26 EDT 2007
Traian Stanev wrote:
> Not sure. I personally haven't seen this exact problem before. Why do
> you think runConfigure is failing? File permission issue?
The failure mode of Xerces' runConfigure is that it just displays the
usage message. And I know for a fact that "./runConfigure -p linux" or
"./runConfigure -plinux" are proper calling syntaxes. My workaround is
to call Xerces' ./configure instead, which properly detects the OS anyway.
I'm surprised that it worked for you. Perhaps I should take this to the
FDO-internals mailing list for further discussion?
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
More information about the fdo-users mailing list
