[fdo-users] Problem with build_linux.sh -- Pool.h and Clear declaration
Gregor Mosheh gregor at hostgis.com
Wed Jul 11 13:54:10 EDT 2007
Hi again.
We've gotten past the build_thirdparty.sh at last, and am now on to
build_linux.sh and a new set of problems.
Any ideas on this one?
Making install in Common
make[4]: Entering directory `/tmp/OpenSource_FDO/Fdo/Unmanaged/Src/Common'
if /bin/sh ../../../../libtool --tag=CXX --mode=compile g++
-DPACKAGE_NAME=\"FDO\" -DPACKAGE_TARNAME=\"fdo\"
-DPACKAGE_VERSION=\"3.2.0\" -DPACKAGE_STRING=\"FDO\ 3.2.0\"
-DPACKAGE_BUGREPORT=\"https://fdocore.osgeo.org\" -DPACKAGE=\"fdo\"
-DVERSION=\"3.2.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
-DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
-DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
-DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I. -I../../Inc
-I/tmp/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/src
-I/tmp/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/src     -MMD -MT
-DFULLPROTO -D__USE_GNU -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -MT
ArrayHelper.lo -MD -MP -MF ".deps/ArrayHelper.Tpo" -c -o ArrayHelper.lo
ArrayHelper.cpp; \
         then mv -f ".deps/ArrayHelper.Tpo" ".deps/ArrayHelper.Plo";
else rm -f ".deps/ArrayHelper.Tpo"; exit 1; fi
  g++ -DPACKAGE_NAME=\"FDO\" -DPACKAGE_TARNAME=\"fdo\"
-DPACKAGE_VERSION=\"3.2.0\" "-DPACKAGE_STRING=\"FDO 3.2.0\""
ArrayHelper.lo -MD -MP -MF .deps/ArrayHelper.Tpo -c ArrayHelper.cpp
-fPIC -DPIC -o .libs/ArrayHelper.o
In file included from ArrayHelper.cpp:108:
../Geometry/Fgf/Pool.h: In destructor `virtual FdoPool<OBJ,
EXC>::~FdoPool()':
../Geometry/Fgf/Pool.h:181: error: there are no arguments to `Clear'
that depend on a template parameter, so a declaration of `Clear' must be
available
../Geometry/Fgf/Pool.h:181: error: (if you use `-fpermissive', G++ will
accept your code, but allowing the use of an undeclared name is deprecated)
make[4]: *** [ArrayHelper.lo] Error 1
make[4]: Leaving directory `/tmp/OpenSource_FDO/Fdo/Unmanaged/Src/Common'
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory `/tmp/OpenSource_FDO/Fdo/Unmanaged/Src'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory `/tmp/OpenSource_FDO/Fdo/Unmanaged'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/tmp/OpenSource_FDO/Fdo'
make: *** [install-recursive] Error 1
If I add -fpermissive to CPPFLAGS per their suggestion, the code is
reduced to a warning. But then I hit upon another problem later...
Making install in Geometry
make[4]: Entering directory `/tmp/OpenSource_FDO/Fdo/Unmanaged/Src/Geometry'
[snip]
In file included from Fgf/LineString.h:29,
                  from Fgf/GeometryFactory2.h:31,
                  from Fgf/CircularArcSegment.h:25,
                  from Fgf/CircularArcSegment.cpp:20:
Fgf/GeometryImpl.h: In member function `virtual void
FdoFgfGeometryImpl<FDO_GEOMETRY_CLASS>::SetFgf(FdoByteArray*, const
FdoByte*, FdoInt32)':
Fgf/GeometryImpl.h:68: error: invalid use of undefined type `struct
FdoFgfGeometryPools'
Fgf/GeometryImpl.h:28: error: forward declaration of `struct
Fgf/GeometryImpl.h: In member function `void
FdoFgfGeometryImpl<FDO_GEOMETRY_CLASS>::SurrenderByteArray()':
Fgf/GeometryImpl.h:154: error: invalid use of undefined type `struct
make[4]: *** [CircularArcSegment.lo] Error 1
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
More information about the fdo-users mailing list
