[fdo-users] Problem with build_linux.sh -- Pool.hand Cleardeclaration
Gavin Cramer gavin.cramer at autodesk.com
Wed Jul 11 14:33:26 EDT 2007
Which version of the code are you compiling -- from the trunk, or an
older branch?  I fixed a problem with the call to Clear() on line 181 in
the 3.2.x branch and the trunk on 2007feb19.
Does your code at line 181 read as...
        Clear()
... or ...
        FdoCollection <OBJ, EXC>::Clear();
...? It should be the latter one.
Gavin
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Gregor Mosheh
Sent: Wednesday, July 11, 2007 2:03 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] Problem with build_linux.sh -- Pool.hand
Cleardeclaration
Traian Stanev wrote:
> What version of GCC are you using? Compilation of templates is
> notoriously inconsistent across GCC versions.
GCC 3.4.6
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting
services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
