[fdo-users] The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Hidekazu Shimaji hshimaji at ybb.ne.jp
Fri Jun 22 20:46:13 EDT 2007
Hello Patrick,
You need add the following path to your "Path" system environment variable.
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\com
They are where fdo files are locationed.
This is because the OSGeo.*.dlls refer other files in those folders.
Try it.
Regards,
Hidekazu
--- original message ---
Hi Guys,
I ran into this error when I try to use FDO in my C# web application. Here
is what I did.
1.) I downloaded 3.2.1 binaries from http://fdo.osgeo.org/download.html
2.) Create a new web application using VS 2005
3.) Add all the OSGeo.*.dll reference
4.) Run the web application then I got that error...
Any idea will be great!!! Thanks in advance.
Cheers,
Patrick
View this message in context: http://www.nabble.com/The-specified-module-could-not-be-found.-%28Exception-from-HRESULT%3A-0x8007007E%29-tf3967241s18162.html#a11262204
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
