[fdo-users] The specified module could not be found. (Exceptionfrom HRESULT: 0x8007007E)
Greg Boone greg.boone at autodesk.com
Mon Jun 25 09:50:41 EDT 2007
Also, use the depends.exe application (or other appropriate NS tool) to
determine modules are missing.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Hidekazu Shimaji
Sent: Friday, June 22, 2007 8:46 PM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] The specified module could not be found.
Hello Patrick,
You need add the following path to your "Path" system environment
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\com
They are where fdo files are locationed.
This is because the OSGeo.*.dlls refer other files in those folders.
Try it.
--- original message ---
Hi Guys,
I ran into this error when I try to use FDO in my C# web application.
is what I did.
1.) I downloaded 3.2.1 binaries from http://fdo.osgeo.org/download.html
2.) Create a new web application using VS 2005
3.) Add all the OSGeo.*.dll reference
4.) Run the web application then I got that error...
Any idea will be great!!! Thanks in advance.
View this message in context:
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
