[fdo-users] Unable to test PostGis provider
Jason Birch Jason.Birch at nanaimo.ca
Tue Jun 26 11:41:48 EDT 2007
Have you installed the MS C++ Runtime SP1?
<http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-
4A14-984D-389C36F85647>
If that doesn't work (after a reboot) run depends.exe on the PostGIS
provider DLL and see if it's having difficulties locating anything.
http://www.dependencywalker.com/
Finally, I wonder if there were changes in libpq.dll between the version
that Mateusz is using and the one you are.
Jason
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Tuesday, June 26, 2007 07:01
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Unable to test PostGis provider
Hi all
i'm trying to test the new pre-release PostGis provider But i am not
able to do anything
In mapguide studio.  when i try to create a new PostGis data connection
i have no connection properties.
There is nothing in the log file...
In Autodesk Map 2008, when i try the same thing i got:
Unable to create connection to provider 'OSGeo.PostGIS.3.2'
Unable to load the FDO Provider: This application has failed to start
because the application configuration is incorrect. Reinstalling the
application may fix this problem.
It seems that the postgis fdo dll is not loading
My configuration
Windows XP sp2
PostGresSql 8.2.4 with PostGis 1.2.1
Mapguide Opensource 1.2 RC1
MapGuide Studio 2008 beta 1
Autodesk Map 2008
FDO PostGIS provider, build 3171
Path to postgreSQL/bin is in the first directory in the PATH Environment
variable fdo dll are well copied in the fdo directory Provider.xml is
well configured
So i'm a bit stucked
I really like to test this provider
Bruno Scott
View this message in context:
http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.ht
ml#a11306259
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
