[fdo-users] RE: Unable to test PostGis provider
Bruno Scott bscott at geomapgis.com
Wed Jun 27 05:59:29 EDT 2007
Even if i have Visual studio 2005 i've installed the MS C++ Runtime SP1
And now i can connect and display data
Thanks
Bruno
Bruno Scott wrote:
> The providers.xml files on the matheus site shows a fdo version 3.2.0.0
> Is it build with this fdo version?
> We use fdo internally in c++ program and we had problem
> making fdo 3.2.2 and 3.2.0 living together!
> could it be the problem?
> JasonBirch wrote:
>> Have you installed the MS C++ Runtime SP1?
>> <http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-
>> 4A14-984D-389C36F85647>
>> If that doesn't work (after a reboot) run depends.exe on the PostGIS
>> provider DLL and see if it's having difficulties locating anything.
>> http://www.dependencywalker.com/
>> Finally, I wonder if there were changes in libpq.dll between the version
>> that Mateusz is using and the one you are.
>> Jason
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>> Sent: Tuesday, June 26, 2007 07:01
>> To: fdo-users at lists.osgeo.org
>> Subject: [fdo-users] Unable to test PostGis provider
>> Hi all
>> i'm trying to test the new pre-release PostGis provider But i am not
>> able to do anything
>> In mapguide studio.  when i try to create a new PostGis data connection
>> i have no connection properties.
>> There is nothing in the log file...
>> In Autodesk Map 2008, when i try the same thing i got:
>> Unable to create connection to provider 'OSGeo.PostGIS.3.2'
>> Unable to load the FDO Provider: This application has failed to start
>> because the application configuration is incorrect. Reinstalling the
>> application may fix this problem.
>> It seems that the postgis fdo dll is not loading
>> My configuration
>> Windows XP sp2
>> PostGresSql 8.2.4 with PostGis 1.2.1
>> Mapguide Opensource 1.2 RC1
>> MapGuide Studio 2008 beta 1
>> Autodesk Map 2008
>> FDO PostGIS provider, build 3171
>> Path to postgreSQL/bin is in the first directory in the PATH Environment
>> variable fdo dll are well copied in the fdo directory Provider.xml is
>> well configured
>> So i'm a bit stucked
>> I really like to test this provider
>> Bruno Scott
>> View this message in context:
>> http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.ht
>> ml#a11306259
>> Sent from the fdo-users mailing list archive at Nabble.com.
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.html#a11321528
More information about the fdo-users mailing list
