[fdo-users] Help with compiling and deploying providers on windows
George McLean gmclean at gorge.net
Fri Mar 16 20:35:51 EDT 2007
I am attempting to get the current MySQL FDO provider.
I have compiled the code on
https://svn.osgeo.org/fdo/
using the build.bat files in
https://svn.osgeo.org/fdo/trunk/Thirdparty/
https://svn.osgeo.org/fdo/trunk/Fdo/ and
https://svn.osgeo.org/fdo/trunk/Providers/GenericRdbms/Src/MySQL/.
On my local machine I copied the following dlls from Providers\GenericRdbms\bin\win32\release
MySQLProvider.dll
MySQLOverrides.dll
to the MapguideOpenSource\Server\Bin\FDO folder replacing the old versions.
Now mapguide will not query the MySQL database. Also I get an exception error in Autodesk Mapguide Studio when opening layers that are created from the MySQL database. The error reads:
'The feature source is invalid. Reason: An exception occurred in FDO component. Unable to load the FDO provider: The specified procedure could not be found.'
I am assuming the compile of the provider dlls worked since I did not see errors. What are the correct steps to deploy the updated provider files?
Thanks
George McLean
More information about the fdo-users mailing list
