FW: [fdo-users] FDO component exception RDBMS
Brent Robinson brent.robinson at autodesk.com
Wed May 2 10:25:12 EDT 2007
Not sure if it went to the whole group so forwarding ...
-----Original Message-----
Sent: Wednesday, May 02, 2007 10:24 AM
To: 'kgrootendorst at baird.com'
Subject: RE: [fdo-users] FDO component exception RDBMS
One case where this can happen is if the mysql client library
(libmysql.dll) is version 4 or earlier. Due to some data types that are
new to MySQL 5, a version 4 client can get the
"Using unsupported buffer type" error when talking to a version 5
server.
If this is the case, then replacing libmysql.dll with a version 5 one
should fix it. For a MapGuide installation, I'm not sure of the exact
location if libmysql but someone else on the [fdo_users] group would
likely know.
If you're sure you have the right version of libmysql, there's also the
chance that a libmysql from another directory is being picked up before
it, depending on the current path.
Brent.
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Tuesday, May 01, 2007 12:36 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO component exception RDBMS
Hello,
Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
When setting up a MySQL connection through Studio, I keep getting the
following error:
An exception occurred in FDO component.  RDBMS: Using unsupported buffer
type: 0  (parameter: 1)
Below is a dump from the server log.  Does anybody have any idea as to
how to fix this?
Error: An exception occurred in FDO component.
        RDBMS: Using unsupported buffer type: 0  (parameter: 1)
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\servi
ces\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute line 103 file
ces\feature\OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open line 815 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\commo
n\manager\FdoConnectionManager.cpp        An exception occurred in FDO
component.
Thanks in advance.
Kevin
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070502/12235d21/attachment.html
More information about the fdo-users mailing list
