[fdo-users] 3.3 GDAL provider does not work with MrSID plugin
Tom Fukushima tom.fukushima at autodesk.com
Tue Nov 6 16:15:39 EST 2007
Hi Frank,
I was trying out the FDO 3.3 GDAL provider for the next MGOS 2.0 release but found that when I tried to use the MrSID and ECW addons (http://home.gdal.org/dl/mapguide/) that I got the following error:
"The application has failed to start because gdal13.dll was not found.  Re-installing the application may fix this problem."
FDO 3.3 now uses gdal14.dll.  Could you make us some new MrSID and ECW plug-ins that are compatible with gdal14.dll.  The exact version in the dll is 1.4.0.0.
Thanks
Tom
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071106/ea51d861/attachment.html
More information about the fdo-users mailing list
