[fdo-users] Fdo Postgis Autogenated identity property
Bruno Scott bscott at geomapgis.com
Fri Nov 16 06:26:14 EST 2007
Actually it is mandatory
there is the piece of code where you can find the limitation:
void SchemaDescription::DescribeSchema(Connection* conn, FdoString*
schemaName)
        ////////////////// SET AUTO-GENERATED TO SINGLE COLUMN PK OF
INTEGRAL TYPE //////////////////
         // TODO: It is possible, that user connects to a datastore that was
not created
         // with FDO, using ApplySchema command, so single column PRIMARY
KEY
         // of integral type, may not have associated sequence named
according scheme:
         // <tablename>_<columnname>_seq
         // The PostGIS provider uses such scheme to bind a sequence to PK
column.
         // TODO: In future, it would be a good idea to automatically
         // replace PK of integral type with serial data type, in
ApplySchema command.
         FdoPtr<FdoDataPropertyDefinitionCollection> propsIdentity;
         propsIdentity = featClass->GetIdentityProperties();
         if (1 == propsIdentity->GetCount())
             FdoPtr<FdoDataPropertyDefinition> propId =
propsIdentity->GetItem(0);
             assert(NULL != propId);
             if (FdoDataType_Int16 == propId->GetDataType()
                 || FdoDataType_Int32 == propId->GetDataType()
                 || FdoDataType_Int64 == propId->GetDataType())
                 propId->SetIsAutoGenerated(true);
With FDO it is possible to create a column with Primary = true and
autogenerate = false.
I think the PostGis provider should not do that assumption and let the user
manage the primary key
if the autogenerate flag is set to false.
Bruno
christophe_geomap wrote:
> When i have only 1 identity property (int32), postgis provider set the
> property autogenerate.
> Is there a way to have 1 identity property (int32) without using a
> sequence or is there a ticket about this ?
> Thanks
> Christophe
View this message in context: http://www.nabble.com/Fdo-Postgis-Autogenated-identity-property-tf4803647s18162.html#a13791420
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
